Lance Pearson
Trailer...the used boat I brought back from Florida, a V20 hull in good shape for a 1977, is on an EZ load trailer
Trailer...the used boat I brought back from Florida, a V20 hull in good shape for a 1977, is on an EZ load trailer and yesterday I saw some rust on the bottom of the frame at the very back and have decided to use my woodworking skills and cut a 4 x 4 of salt treated wood to shape to fit inside then drill 1/4" holes and through bolt it in place to brace that last 2' of frame as a conservative precaution. The rest is solid but that must have been left to sit with salt water in it over time. Sides and top of the tall rectangular steel tube frame are solid. This would not be a 50 year fix but in wood terms would be inserting an internal cripple to keep the bracing of the rectangular shape solid. The trailer tracks very well and I like it so will do this rather than welding and over time if anything more happens will just consider buying a new trailer tho I believe this will work fine as it is working as is. I've named the boat K-2 in remembrance of two females in my life now passed on, Karen and Kate. I will order the graphic for the sides in the spring. Going to be in the teens for low tonight here in Chester, Va.
It already has four holes drilled through the center of the section...two hold the license bracket on and the cross brace, two more spaced about 18" apart moving forward on the trailer. I'll fill the section but look for the kind of u shaped brackets and bolt it in place with that given your advice.
The last section really does not carry a ton of the weight but I want it to be as good as I can make it. If need be I'll have a u shaped section welded to it.
We will see what I can make work out without drilling more holes and using the holes that are there. I can shape a 4 x 4 to fit inside it with my bench saw and fill the cavity then drill the holes in the wood for the existing holes which should be enough to hold it in place and it will stiffen them up very considerably.. I was just going to use 1/4" bolts but want to be conservative so will go this way. I might also use squared off U bolts but I much prefer through bolts.. Will measure and look. If I remove the back bolts the spreader bar between the rails, last one is affixed to them so I will have to put the stern of the boat on 6 x 6 wood blocks to get the weight off it so the rails can't spread while I do it. Fortunately with two vintage corvettes I also have heavy duty jack stands and can block the back up to relieve the weight while I work quickly.
Yep... what they said.
Destroyer, Skool's Out use to call those transom destroyers be cause they would do more harm than good for a transom. The slight rocking of the boat on the trailer would push on the engine because the boat and trailer were not the same if you can visualize that.
I figure they're made by the same folks who make "submersible" trailer lights, rubber coated anchor chains, boat horns, stainless hose clamps with black iron screws, boat trailer brake systems, those hollow black keel rollers that put all the weight on the white plastic bushings and hold water to rust out the roller pin...........
The structure of the rectangular steel tube depends on all four sides being intact. Replacing a short section of the bottom with solid wood with drain grooves cut in it as an inside "cripple" will effectively accomplish that structurally. The holes drilled in the frame were by EZ loader and do not effect it in any material way as much as not having four sides bracing force against one another lest you drill five holes top to bottom in a row or something silly like that. I can use their holes once the block is in place and snug it in there. Blocks are cut and next warm day I'll go slide them in and snug them down.
I'm pretty confident this will extend the life of the trailer quite a lot. It just got towed 617 miles from Orange Park, Fla to Chester, Va. on I 95...boat followed my suv all the way home at a sedate 65 miles per hour without them.
1. Destroyer, your sarcasm does not suit you well. Many of us also are competent to make mechanical judgements.
2. The trailer is galvanized steel with some type of coating on it for some reason
3. The wood is pressure treated, I just said it was salt as that was another way of saying it.
4. Your comments were listened to and considered. Please don't lecture me as tho I have no common sense. I have just as much as you do and as many or more degrees, experiences and responsibilities in my background. You probably don't want to go there.
5. With respect to pictures I posted a link to my site with dozens and dozens of full sized, non compressed photos of the boat. This site's photo policies makes them so small and so compressed they are useless. If you are sunk into your big arm chair watching football look for that post on this thread and you can see better photos. The option is yours. Takes away from the charm of your native sarcasm when you keep whining the same song when it's been responded to.
6. Not everyone is going to agree with everything you say but I did consider it. Not a lot of engineers have the balance to run the entire company. I always thought it had something to do with tunnel vision personally.
7. Have a good holiday and I appreciate your initial advice which I did consider and modify my plans accordingly within the frame of my own judgment as an input. Thanks for that input.
8. I removed most of the posting considering the responses and the individuals responding. Seems more sensible to deal with rational people.
Lance Pearson said:Your sarcasm and overbearing dictatorial manner have convinced me there is little point to staying on this site and have dropped it. If I have to depend on info from guys named Destroyer this is not the site for me.
Believe me, you won't miss me and I sure won't miss you. removing assholes from my life pretty much covers it.
Lance
I'm with you B, i'm trying to go "Travis McGee" as fast as i can.
