YO SKOOL
You sure having a thicker transom is ok. Dont want to get stuck notching out the transom for the steering tube. It was 1 1/2 before I tore it out, and look at it now. I still need to wrap some cloth up over the transom and intop the splash well. She's Thick, but to thick ?? ??? ??? ??? ???
if you want to wrap it just use the grinder to take down the glass around the top of the transom then lay glass in to make it back level with what you ground out.
Should I wrap it  ??? figured I should for strenght, but then again do I really need to. From why I recall, the spashwell/cap was never attached directly to the inner skin. What ya think I should do.  ???
i like them wrapped for looks and strength. just gring down about 3 inch inside and out thern wrap it in the area you ground to not make it to thick.
