Yammy fuel problems...
ssiredfish
How bout it gents? Been awhile since I could post anything and honestly I dont really have a good excuse for why so I apologize. Anyway, glad to be back and I gots a brainscratcher for ya.....
Here ya go.........
2007 Yamaha F150TXR 4-stroke
Problem: Engine is starving for fuel at high speed around 4100rpms. Does not over-rev and does not sputter. Matter of fact it acts as if something is sitting behind the throttle and you can only push the throttle so far. But after it hits 4100 you can throw it all the way down and she doesn't answer.
Fuel flow: Engine----->Fuel econ computer(FEC)----->Canister Fuel filter------>Fuel pickup tube------>Gas tank
Diagnostic: Replaced fuel filter(canister). No change. Cleaned the H2O/Fuel seperator. No change. Took a gas can down the other day and ran it into the H2O/Fuel seperator directly, ran like a champ(actually the best performance to date). Reconnected fittings at engine and plugged into fuel flow before the FEC from the gas can. Ran like it typically does, 5100rpms. Reconnected that back up and plugged into fuel flow before the canister filter from the gas can. Typical performance, 5100rpms.
At this point it is lookin like a bad main fuel hose from the tank, dirty pickup tube, or bad bulb because everything off the can is optimal......
I reconnected my main fuel line back up to the canister filter and the bulb wouldn't pump. Oh god tell me thats all it is. So I changed the bulb and re-pumped till tight and got runnin with the system set up the way it has always been. After 3mins she starts dropping rpms. Now I can pump the bulb while runnin and she will pick back up to optimum speed but as soon as you stop pumping, she starts dumping speed.
Ok, so lets go back to the gas can again and plug in before the filter then we will go to the tank after that. Never made it. As soon as I start pullin gas from the can before the filter, she bogs down again and won't recover.
I am thoroughly confused......Ran fine off the gas can, crappy off the tank and then crappy off the gas can for the first time
Im gettin ticked
I am goin to replace fuel hoses today and inspect/clean the pickup tube. Any other ideas? Do you think I have completly ruled out a problem at the engine? I guess I should have ran direct from the can into the H20/Fuel sep. when she bogged down the last time to see if it improved but I was gettin pretty mad and had to get home for daddy duty
UPDATE: Took it out yesterday and the day before. Ran like a champ. I dunno what to make of this. Starting to apper like a floating blockage or some crap. If Wed. is blown out Im goin for that pickup tube......
if you haven't done it in the past 5 or 6 years, replace the fuel line, even ethanol free fuel has additives in it that eats stuff up. Replace the primer bulb with one made by an engine manufacture(Merc, Yamaha, Bomb). If you've replace the filter on the engine, check and replace the little filter on top of the vapor separator tank, we call it the horse shoe filter, it makes a 180 degree turn, you can see it behind the intake runners, just on top of the VST,
Thanks man, hoses are 15months old and I should have mentioned engine has 300hrs on it. The filter you are refering to is that the #20? Or is there one before that?
