wellcraftv20step
looking at a 1992 yamaha 250 with 98 psi across the board. is this number a little low? thanks
also understand that a compression test is to be performed on a warm engine at WOT
i think he means with the throttle in the wide open position, not actually running. that would be a little tricky..
it makes your thumb pretty hot if the engine is up to temp, leaves a funny burnt ring on your thumb(don't ask how)Whats wrong with thumbin the hole?? My right thumb is accurate to about 3psi. My left thumb however, is off about 6psi![]()
THERE used to be a guy on ebay that manufactered a 2 piece shift rod for yamaha ,, it did not require removing the power head and was a pretty easey fix
