jamesbalog
may be buying one shortly, whats the least amount of hp you would put on a center console v20?
Mine runs out great with my '75 merc 115.... It is generally accepted here that 90 is the smallest that will work BUT a modern 90 SHOULD have the same power to the prop as my old 115 soooo you MIGHT be able to get by with a little less in a modern 2 stroke.... A 4 stroke would need to be a little bigger due to weight.
Your use will also affect this... If you generally go out with 2 huge coolers full of ice and 4 guys n gear you will have much different results than if you boat solo with minimal gear.
115 is the smallest I would go ,I have a 150 hanging off mine even if a 90 would be ok I would go no smaller than a 115 that's just my opinion. I also think that the plate mounted on the boat says that too
2004 4 stroke 90hp on a v20?
