#4 is what most carb 2 strokes use up to 10 ft from the engine, I prefer #2 all the way, but it is sometimes hard to get thru the engine harness loom. High quality wire, good cable ends and tight connections go a long ways. You system is only as good as the weakest point, whether it be a bad connection, crappy wire, or a cheap battery switch
