Deepdrop2*
Some say avoid the I/0’s …opinions ?
Aware of the maintenance issues especially salt water
Non ethenol gas? Not in nj. You can’t get that hereWelcome Deepdrop2! I've had a 1977 V20 170 I/O since 06. When I bought it, it had sat outside uncovered for at least five years. Guy I got it from in Virginia Beach, Va. said the motor had been rebuilt 5 years ago by Jasper engines and he never got it started. He cranked it and I immediately knew the timing was out. Got it home and had it running in ten minutes. It had set up so long the exhaust ports on the head had holes rusted through them. I pulled the motor out and found the transom core had rotted out. Rebuilt the transom, sealed it all up and rebuilt the motor again with a new 460 Ford marinized head. Put it all back together and have had really no problems since. Watch out for cam seals behind the water pump impeller leaking, easy to replace. And I installed a Pertronix electronic ignition, made a BIG difference on performance and starting. Just replaced the lower unit last year with a SEI unit. Good warranty on that. Haven't needed it. Always run 40w oil in the motor and premium nonethanol gas and it runs great. Top speed is 42 with five adults onboard. I really like the Mercruiser 170, just do the regular maintenance and you'll be fine.
