V21 Swim Platform
I would like to think that all swim platforms are through bolted, at least at the top of them.
Thru-bolted is the way to go. Not sure about a factory V-21 platform. The P.O. replace the one on my boat and thru-bolted with starboard backing plate and generous 5200 around the bolts.
stock was just screwed in.....I had to have my brace replaced. I use mine a good bit and went with oversized squared aluminum. Screwed in makes about as much sense as those dinky drains at the back of the deck....or leftover flooring laminate like they used on the gunnels......
Mine (96) was just screwed in from the factory. I drilled it through, used SS fender washers and 5/16 SS Carriage bolts. Coated the threads with Never-Seez and sealed the hole with 5200.
