jasoncooperpcola
God
Today i checked compression on both engines.
The port engine has the following compression: #1- 113 #2- 120 #3- 115 #4- 119 #5- 115 #6- 120
The Starboard engine has the following compression: #1- 115 #2-105 #3- 119 #4- 120 #5- 115 #6-120
Should i be worried about the 105 in the starboard engine? That is the engine thats being troublesome.
Also checked lower units today. Both units turned about 1 1/8th of a turn with two full turns of the flywheel. So lower units is not my problem. Is there any other reason why the starboard engine will only reach 4500 rpm? I'm thinking it may be a carb issue. It doesn't worry my dad though. I just want to see what the boat is capable of doing.
