Aren't V6 engines pretty well balanced with the engine up? I mean, isn't there enough weight to balance out most of the bounce?
balance has nothing to do with the hull flexing and if it is supported to the trailer then you a stressing your transom and motor, but the ones that support to the hull are good just not the trailer ones. i'm not talking about the motor bouncing it's the hull that bounces but if the motor is braced to the trailer the only thing to give is your transom or your tilt trim cylinders, it can cause them to leak and go bad faster. Parker boats will void your hull warranty if you use one of them on there boats, but heck it's your boats kill'em if you want.
..... but I do stack stroke limiters around the cylinder shaft when I haul long distances, it keeps the pressure off the trim. ..... Takes about 30 secs to put them on, Plus they are pretty cheap to buy at Tractor Supply.
What about strapping the boat to the trailer and using a t-saver? That way neither one bounces.
Planning on doing some bouncing on Mrs. Blue's tranny this weekend. No transom saver.![]()
