I just bought a 1990 V20 fisherman which is generally in great condition though I am concerned that there is a crack in the transom above the uppermost engine connection bolt; we are taking the engine off and will take core samples to see if the transom is good or not - if no problem will just reseal everything. If there is an issue we plan on cutting the transom out from inside to the outer skin so as not to ruin the gel coat on the outside as it is pristine and then rebuild the transom from the inside.
My question really is there is a soft spot in the floor in front of the front console seat that needs to be repaired; what is the best way to do this? Cut it out and reinforce it and then put the section back and repaint the floor or is there a better way? The soft spot is about 24" wide by 12" deep (bow to stern)
