Boat test
Just as an FYI my Yamaha manual says 4500 -5500 as the WOT setting. Seems very strange to have such a wide range on RPM for WOT.
Ran my boat a local lake this last weekend with the Navman system and a Lowrance 350 GPS/FF/Plotter, full fuel ( 60 gal ) 1 person, no T-top, med load of gear.
Using the Boating Mag test profile ( 90% of fuel cap 54 gal.) Boat had maximum range of 186 statute miles.
Test results are as follows.
RPM MPH GPH Range MPG
1000 5.3 2.4 119 2.2
2000 8.2 4.5 98 1.8
2500 13.0 6.1 115 2.1
3000 20.5 7.1 156 2.9
3500 28.3 8.2 186 3.4
4000 33.5 10.3 176 3.2
4500 38.6 12.0 174 3.2
5000 43.4 15.6 150 2.8
5400 48.5 20.1 130 2.4
It's nice to know I can get a 150 mile range with a wide range of speeds. After looking at the numbers I am going to add a 19 gal permanent tank under the console. We regularly fish 30-50 miles offshore for tuna and will need the extra fuel for trolling and saftey margin.
I ordered a T-top to be made locally and that will increase fuel usage also.
These tests were made under ideal conditions, no wind, 75 degrees and on a lake with no swell or chop. Please do not use these numbers for your boat.
I can say that I have been very satisfied with the Navman unit so far. It says to mount sensor in a vertical position for best results but I mounted mine right above the gas tank in a horizontal position and put a small fuel filter right in front of it, seems to work great. The features are much better than the FloScan that I had in my last boat.
You get current consumption,total, trip & fuel remaining w/alarm. You do have to reset the fuel remaining after each fillup. You can also set it to read Liters, Imp. gallons and US gallons and also has a calibration mode if readings are not exact. My Floscan system was consistently off by about 3-5 % over and under.
This thing a great buy at $149.00 from outerbanks.com
no tax and no shipping charges.
No I don't work there but I would if I could get a big discount ;D
Charlie Buzzetti
