Boston Habba
2006 DF 140
Tilt up doesn't work. Both the switch on the binnacle and the cowling. Try to trim up from either gives nothing. Press down and trim motor runs. I have assumed that both switches haven't gone bad at the same time.
It has a single combined up/down relay. Clicks when down is pressed. Nothing when up is pressed. Assumed that the problem was in the relay. New relay didn't solve problem. There is a switch that limits up travel but I have eliminated that as a cause.
Any other Suzuki owner have the same problem? Any ideas?
Thanks
Thanks
