Sealing tank hatch
I removed the tank cover from my 1991 V20 cuddy last year when I had a fuel problem. I put it back on without using new caulk. My tank hatch is in great shape with no moisture or flex whatsoever. I pulled it off yesterday so that I could put down new caulk. I scraped off all of the old caulk which was still stuck on very well. I was pleased to see the tank and all fittings, hoses, etc. were in very good shape.
What caulk/sealant should I use to put the hatch cover back on? Should I put the caulk down, then put the hatch over it or should I just put the hatch on then caulk from the outside (or both).
I'd do both, but don't use 5200. Find a good silicone caulk for above waterline use. Clean up all edges before applying.
I agree, 5200 will stick forever and you may want to get back in there? I used that boat life stuff, did a good job and will come off if I need to get back in there again.
And yes put a bead down, drop cover on and do it again be sealed perfect!!
just did my hatch cover as well. I ran a healthy bead around the floor, then dumped the cover on and hit it again. The material I used was the 3m 4000UV fast cure. I'm sure any compatible chaulk is fine I would just make sure it is UV tolerant.
