chesapeake724
If I can't fish, at least it's been mild enough to work on the boat.
Before
After
I'm going to add some Taco flex trim around the panel to clean it up. There are a few chips on the edges, plus the trim should seal the panel a little better. I might even put an additional weather strip underneath.
Before, there was just a bus/fuse bar combo screwed to the back of the panel. I decided to add a house battery and have a two banks. Will clean up the routing some, but here's the work in progress.
I'll fabricate some sort of cover so all that stuff isn't exposed.
Before
After
