Hi guys ,I have a question about props and tubing
I was told that a lower # pitch will be better for tubing
I was running a 13 1/4 x 17 on a 115hp johnson while tubing, I had a adult on the tube and was having trouble getting him out of the hole abuot 30 seconds into the ride my rpms shot up so i backed down on the throlle tryed agan tnd and the same thing happen when i got back i checked for a spun prop but the prop looked ok (its a fixed hub) could it have spun without showing signs that it did,, I an going to pick up a used 13 1/4 x 15 and see if that helps with the hole shot
