Project update
i know how everyone likes pictures (and so do I) so tomorow i will snap some of the v-20 tomorow. still now finished but looking better. so ya'll try not to laugh to hard at it.
Looks like a nice boat!! But how were they going to drive it?? Ladder were the wheel should be??
Looks to be lots of space around that bracket?? should be bolted up tight to the transom and sealed??
But looks like you have something solid to start with!!
naw i have a center console that i just received which will be replacing the old homemade one that was in there. and the bracket is fully enclosed so no water can get inside from the back the 4 mounting holes are sealed right now but i have to make some shims for the last two on the top so theres somting between the bracket and transom.
This pic concerns me. The bracket should bolt to the transom, and go right tight against it. bracket uses the transom for leverage and is sealed all around.
It looks like its not tight from that pic??
There is going to be a ton of weight on them bolts if the bracket is just hanging there. also there is some holes on that transom that should be fixed and I think I would have done that before mounting the bracket.
If was me i would remove the bracket and make sure transom is solid, fill all holes and what else might be needed, then remount the bracket with what ever you may need for shims and stuff.
the transom has a huge curve but where it mounts to the bracker its pretty flat. that is why it looks loose. there are 3 small holes that will be filled and the two big ones are for the rigging. i'll take some closer pictures so you can see what im talking about tomorow.
Thanks for he update!!
My bracket was also a straight bracket off a Sea Craft, I had to make shims on the corners of the swim platform. I guess what thru me off was your bracket is so wide!
My bracket was narrow so it fit right flat in the middle, and no space.
OK carry on! LOL
yep she is a wide one. to fix the gap since its so long im just gonna scribe a peice of lumber then glass is and screw it down to the top of the bracket. so you cant see the gap from up top. and where the final two bolts go i will shim it up wtih small aluminum plates.
