Ambush
I took out my v20 for a ride today and had a couple of problems I need some advice on.
1. The strap on my winch broke retriving the boat.
Q. do you guys use a safety strap on your boat or a chain or what?
I'm thinking if that happned on the road that could of been very bad.
2. I'm having hard starting cold, after it warms up I found it will start pretty easy in the first notch position on the throttle. Other times I have to give it full throttle to start. Some times it will start at idle, I'm thinking carb rebuild?
3. Today it realy bogged down at full throttle then it was ok?
Again carb?
4. I'm also thinking timing? However my tach is not working.
TIA
Again carb?
TIA
