Raymiltier
So i just brought the V back home after taking it to work so that I could use the shop to replace the lower shift cable. Before towing her home I put on the flush rig and ran the engine until it came up to temp about 170, shut her down and took her home. I parked the boat in the driveway instead of the usual spot in the back yard because of the rain we have had ALL WEEK. SO I'm sitting there watching TV when I here what sounds like a car in the driveway. I go to check it out and its the V running! I jump in the boat look at the key, its in the off position. so I switch it to on and then off and she cuts off. I think she only ran for a minute or two tops, and the temp gauge only read about 80 degrees. So I let her sit for a minute hooked up the muffs and ran her to make sure my water pump wasn't shot. she came up to temp and held for 15 minutes. this time i turned off the batteries before leaving. Is it possessed or is there a logical explanation?
