Port Dash Area
My port side dash had two layers of vinyl floor tiles glued to it. I spent about 2 hrs getting all the glue off of it with acetone. Now I have to fill all the holes and mount my new (to me) fishfinder over there.
I was going to use the stuff HAMMER sent me to just recover the dash, but I am worried that the black will overheat the fishfinder.
I am thinking that I will fill the holes with Formula 27 and then paint.
Before
Now
This will have to be mounted on the port dash.
Any thoughts?
Randleman, you may want to use something else then what I used. I noticed a small spot on mine not sticking. "two bubbles". Not unless you used some of that 3mm spray glue. I should have taken the time to patch my holes. But for now, its ok. Be carefull when or if you use that 3mm spary its strong stuff. I should have used more, but once you spray it on, you gotta have six pairs of arms to get her down on the first try.
You could patch and repaint or just cover it over with some thin starboard.
R'man...will the Si-Tex sit just behind the widshield support so you access the controlls to right of support and view screen left of it...if so, that's what I'd be shootin' for...right in that front corner...JMHO... ;) ...
mine has been like this since 1987.  same bottom machine & loran (for you kids, that was pre-gps) no issues with the black.
and they both still work.
Yep, just like Phat has his, I took it out and fitted it yesterday, I can reach the buttons without having to get out of my seat, which is good cause I get wedged in there pretty good.
That's where my Furuno 600L is. Fill the holes with your choice of filler, then get a spray can of genreal purpose adhesive. I used "shelf liner" from the domestic section of WalMart. You will want "something" on the dash, and starboard ain't it. Get something that is nonslip, so that when you toss a jig, or bottle of sunscree or whatever up there, it'll somewhat stay put.
JMO
Here's a couple pics that show mine. Of course, one is a little too far away, and the other is just a little too close ???
Yep, that's what controls my onboard network, linking all my electronics, nav data, real time weather, sea surface temp, side scan sonar, and a hot link to WellcraftV20.com.....
or maybe it's just a plano tackle box that hold the daily critical items for any given fishing trip, terminal tackle, swivels, assorted hooks, sinkers, and whatever jigs or rigs may be being used at the time ;D
I liked the first explanation better.
You should have added that you found a way to make ocean water act as
your network cable, by placing a special transmitter box under your dock.
Sorry, it seems I'm in a bit of a smart a$$ mood this morning, and I couldn't stop myself. But I'm having fun today ;D
Nice 760, I got one just like it. As accurate as they get, but a little slow to track when running above 30(but there only rated to 40 MPH).
I would clean up the dash, fill with Formula 27 sand smooth, no need for paint! Paint just will chip and look like crap later!!
ferm, that was bought in 82 new for $1400 dollars & still works great. this is the 3 boat it has been on. i started to dump it 10 years ago for all gps(with loran conversion). glad i didn't those conversion numbers are way off. once i get there with the loran, i get a good gps number, then next time i use the gps to find it.
