westcoastv20
Anyone have a good way to remove old pinstripping? Or should I ask, is there an easy way to remove pinstriping? Heat gun, blow dryer, chemicals to use???
thanks in advance
thanks in advance
Thanks boys. So many choices. I will let you know how it goes.
By the way, does anyone know a where I might get the replacement pinstriping and V20 designation? Or am i stuck just re-doing the pinstriping with something off the shelf.
I had one like that and I rubbed flour in the adhesive and used the wheel on it.... worked fairly well
White..
My first thought was dirt but I figured it might scratch the gelcoat.... I figured flour was fine enough to not hurt anything while "drying" the dang goo that otherwise just wants to make a mess.... I have also just sprayed with wd40 and used a plastic scraper but it never really seemed to get it all off.
Smoke, now you got me wantin' to try Bakin' Soda....![]()
