captbent
INSTALLED NEW OUTDRIVE, LINED UP WITH TOOL FIRST, IN FWD ;D OK NOW IT GOES BAD NEW SHIFT CABLE INNER DID NOT KNOW THAT IT WAS TO LONG THAT IT HAD TO BE CUT TO SIZE SO I KINCKED IT UP SHIFTING GEARS NEW SOMETHING WRONG, PULLED OUTDRIVE BACK OFF SEE SHIFT CABLE NOT WORKING FOND KINCK AT CABLE GUIDE UP AT SHIFT LEVER , CUT INNER CABLE AND PULLED OUT , OUTER CABLE GOOD SO ILL REPLACE INNER CABLE THIS WEEK,I JUST READ THAT IT SAYS THE INNER CABLE MUST EXTEND 1 3/8s FROM THE CABLE GUIDE INSERT IN FWD DOES THIS SOUND RIGHT GUYS
