non-ethanol gas
Rode out to the Eagle Mart by the Coast Guard base in Elizabeth City and bought 25.75 gallons of 93 octane non-ethanol gas yesterday. It was 4.34 a gallon. I'm gonna drain out all of the gas left in my tanks before filling with non-ethanol. I haven't had any trouble with my 170 I/O yet but dont want to later on either. The last time I took it out it had a little hesitation when throttling up, thinking it may be the old 10% ethanol gas. Anybody else changed over to non-ethanol gas and have you seen any difference in performance? Since I live close to Va. I looked there and found non- ethanol100 octane at the Suffolk Airport. Might have to get me some of that!
I run non ethanol in everything except daily driven gas vehicles. Boats, lawn equipment, motor home, etc. It runs about 3.99 a gallon near me, and a lot of stations have started carrying it. Def a good idea.
I had an old runabout several years ago that started running like crap with it, mixed a few 6 gallon cans of non ethanol with an additive and was able to clear it up. Had a chainsaw and leaf blower that I ran the hell out of regularly that started running like crap and had to go through the carbs, that's when I switched over to non ethanol exclusively.
Here's a site that will tell you who has it.
http://wellcraftv20.com/community/showthread.php?t=14635
Unfortunately, there is not a single registered E0 gas station in NJ. You would think with all the boating that is done here they would sell it at marinas, etc. But I cannot find any that do. They may be out there, but they are hidden from public view. This may be the result of irresponsible legislation, something New Jersey is well noted for. :bat:
No.... that could never happen.
I seriously don't know how people in NJ, NY, California, and Illinois live there.
Well, for NJ, 196 miles of white sandy beaches probably have something to do with it, along with mountains, farms, forests, pine barrens and the like. If we could just get rid of the dumb politicians, and the people that keep electing them, this state would really be heaven.
Can find it at multiple stations down here, and most marinas have switched over to it as well. Florida did away with the ethanol mandate, but the refineries are still blending it for road use.
I keep my boat on the trailer, sometimes in the water but I only have a floating dock... No lift yet. I always fill from the gas stations, very rarely dockside. I fill with low octane (87?) if I am heading out on a long trip and know I'll use the majority of the fuel. If I'm filling after a trip or if it's unlikely that I'll use most of the fuel, then I'll go with the high octane (93?). I have not subscribed to the prices of ethanol free gas yet because I haven't had any fuel issues. For my mower and hand tools I also use high octane but not E free. I used to fill up after each trip (which I prefer so I know how much fuel I used), to prevent moisture in the tank, but now I mostly fill up before each trip so that I'm burning fresh gas.
have a friend with an ethanol test kit. he went around a couple of years ago testing the amount of ethanol in various brands of gas. he found out most of your cheaper "off brands" had much less than the name brands, some almost zero. the sticker on the pumps says "may contain up to 10%" the ethanol is added when the gas is delivered to the station. the tanker gets 90% gas and then blends up to 10% ethanol and depends on the sloshing and movement to the station to blend.
here is a link for a test kit, but i just made one out of a caper bottle
http://www.amazon.com/Briggs-Stratt...qid=1395591085&sr=8-1&keywords=ethanol+tester
Yea, I haven't had any trouble with the boat being an I/O but my weed eater, leaf blower and chain saws really have a hard time swallowing the ethanol. I've been running 93 in my truck since new and had no trouble. All my 2 cycle motors really dont like it, even with stabilizer. I think the trick is use it quick and don't let it sit in the tank very long. The E15 is really gonna cause trouble!
Down time and the price of new carbs (nobody rebuilds chinese carbs for small 2 stroke equipment anymore), plus the machine running like crap isn't worth saving 70 cents a gallon to me. I still add stabilzer, or for the small 2 stroke stuff I use the stihl silver bottle 2 stroke oil which has them already included.
same here, daily or weekly used stuff gets e10, other stuff gets e0.
I know it might not make a difference, but I would like to see the air to fuel ratio of an outboard without an 02 sensor running ethanol and non-ethanol fuel. I imagine the ethanol fueled engine would run leaner.
A 10% blend isn't supposed to lean out the engine to much as the lower viscosity of it allows it to compensate some there. And if you do the math you only need about 4-5% more E-10 than regular pure gas to achieve the same power output. And with ethanols cooling effect it isn't a problem either. 15% and up is where you start playing on thin ice and worry.
Finally got around to draining my gas tanks yesterday. My 77 has saddle tanks with the fill up towards the front so I dropped the bow down before draining. I taped a clear 3/8 hose to a small dowel rod and positioned it in the bottom front corner of each tank to drain them. It pulled all but a teaspoon out. Got 12 gallons out all together, the last 2 gallons looked like milk! I had put Stabil and Gas Shok in last fall and it still absorbed moisture. Filled it back up with 93 octane non-ethanol gas, should be good to go as soon as I change the fuel filter. Did I say I hate Ethanol!! Ha Ha!!
Glad you got it out of there Cfelton. 17% water!
And your V is obviously well taken care of and maintained. Imagine whats lurking in the tanks of boats whose owners aren't as meticulous.
Even being meticulous doesn't help when all you can get is E10. Here in NJ our only recourse is to completely drain the tank all the time. (and you know that's not going to happen).
By the way, has anyone noticed that as a nation, we've accepted paying 70 cents more for a gallon of non ethanol gas? WHY? It costs the producers ZERO cents more...yet they charge more and act like they are doing us a favor by selling it. Talk about a RIP OFF!!!
Only 70 cents more a gallon, not down here. Try $1.25 a gallon more for ethanol free. It's still cheaper than having to do carbs all the time, and not having to worry about vapor lock. My air cooled KOHLER's on the mowers HATE ethanol blended fuel, and vapor lock anytime you put a hard load on them and get em hot.
