New to this site and New to the V-20
Bpitz15
Hey guys,
I picked up this 1983 Step-lift cuddy with a 2003 Suzuki 115 4-stroke (http://wellcraftv20.com/community/showthread.php?t=19197) a little over a month ago and have been working on as much as possible after my work hours.
So far I have....:
1. Purchased a Veada lounge seat in all white with legs and storage (http://veada.com/boat-lounge-seats/back-to-back-boat-seats-ld20014.html). I have not installed it yet, but that will come in a week or two. I went this route to make the GF and friends happy when I'm not taking the boat out fishing.
2. I have used a rubber wheel to strip off all adhesive stickers, pin striping, old emblems, etc... This process has left what looks to be in tact wax or gel coat where the rest of the boat has oxidized. I am still looking into a way to repair or remove this lair before I polish and wax the hull. I may just cover them up with new pin-striping and new vinyl striping.
3. I have purchased MaryKates on&off, a fiberglass repair kit, rod holders, flag holders (for diving and USA!) teak cleaner with sikkens cetol, Protec boat detail kit, wellcraft emblems, and other odds and ends
4. I have changed all oils, filters, spark plugs on the Zuke' with all recommended brands and weights. This took the uncertainties out of purchasing a used motor and gave me peace of mind.
5. I most recently removed the abandoned 60 gallon fuel tank and cleaned out the hull of all debris. The previous owner tried the power washer method. I, fortunately had access to a mini-excavator and went to town with that. We managed to loosen the tank with the mini, but couldn't get the tank out since I left so much foam in tact. I ended up using a cutting wheel, cut a 1' section out of the middle of the tank and took it out that way. I did discover 3 different holes in the aluminum and discovered that all fiberglass was in tact underneath! The whole process of removing the tank and getting the foam removed took only 4 hours.
I have been searching the forum quite a bit and I think I have the 44.75" x 31" , 60 gallon tank, however the opening in the boat is 47.5"x32". I should have measured the tank prior to chopping it up, but I was in the zone. Can anyone give me a part number for a moeller gas tank that has been dropped into the factory location? I would like to purchase this as soon as possible, but havent developed a definitive answer as to which part number i could use. Any help would be appreciated here.
I am very excited to get this thing in the water (hopefully around July 4th) and I will absolutely keep this thread updated.
Brandon (MA,CT area)
Welcome aboard. Word to the wise, Don't let Stink get his hands on the mini-excavator, it will never be the same again.. What you have done so far is great. I have no number for a Moeller tank. There are a few fab shops around Fl that can make a new one out of aluminum.
Maddsen & Co. made me one. Bob's Welding and Fab has made them for me and a few others.. Bob's leaked like a sieve, Therefore, I recommend leak testing it before you get too far along on the re-installation. I like to coat the aluminum tanks with coal tar resin prior to installation. Nothing is tougher IMO..
Hi Bpitz15. Welcome to the site. Great entrance.. not all of us have access to an excavator. I'm jealous. Nice looking boat. That's a great pic of the side of the boat looking thru the side view mirror. Love that one. You were right to remove that tank. Judging by the pic of that one hole it was an explosion waiting to happen. Sorry I can't help you with the tank size, but there will be other, more knowledgable people along shortly that will be able to. For now, welcome and happy boating. :beer:
Yea the mirror shot is cool for sure.....You give that hull a wet sand, compound and wax you may be able to get that hull pretty close to what that stripe looks like. I had the same effect with a large vinyl sticker on the side of mine...its nearly invisible now.
OOOOOOoooo! good idea!! I may have to give that a try! What grit paper should I go with?
Thanks for the warm welcome everybody. That pic with it in my mirror was the day I took her home.
when I did my 84 (same as 83 I think) i didn't find a Moeller that was quite right. fill & vents are in wrong place. Took the old one to Atlantic Welding Bayville, NJ. They matched the outside dimensions but didn't write them on the receipt, sorry. They did use thicker aluminum and added more baffles so it went from a 60 gal to a 57 gal.
Don't forget. the tank compartment is designed to be a dry space. It does not drain to bilge! always SEAL the hatch!
I don't mind dropping into the 40-50 gallon range in my boat. I think I just need to do the research here and choose my best option. I would like to avoid going custom built for this as I am trying to keep the costs down.
I think I did the heavy stuff with 800 first and then 1200 if I recall? Do a few google searches and you'll find everyone's favorite method. I had the garden hose on mist in one hand and sandpaper in the other and just went at it.
finally got her in the water for the first time on Friday. I planned on it being a shake down run where I would learn all of her strengths and faults. I learned a couple things...
Everything started off well, got her launched, started right up, went through the no wake zone like it should. I started to give her throttle, planed her out and she started bogging down. Crap.
I started doing the analysis...I checked the bulb, it didn't hold pressure when running...had my buddy keep pumping on it and the motor ran fine. Unfortunately for me, my buddy doesn't have the forearms of Popeye so I puttered back in to the launch and took her out.
It's time to diagnose the problem. I am running off of a 6.6 gallon auxiliary tank at the moment. I haven't had the time to purchase a new fuel tank yet but I don't know if it could be undersized fuel lines from the aux tank... i dont know if my fuel pump is going on my motor, and I dont know if its my fuel filter or fuel/water separator.
First things first, I will buy a new fuel/water separator filter, I'll buy a new secondary fuel filter and see what that does.
Second, I'd like to purchase a new gas tank this week and hopefully get that in soon. That should help with the fuel line size issue.
Thirdly, i'd like some help from this forum, do you think I should look into purchasing a new fuel pump or should I trouble shoot first?
Any other ideas/opinions would be greatly appreciated.
Does sound like fuel pump...assuming ya had the vent open on the aux tank...lol
sure did! hahaha
Given the fact that the primer bulb got hard when the motor was off and got soft when it was running leads me to believe that not only should I replace the fuel filter, water separator and pump, but also pick up a new primer bulb... who knows if it has a bad valve...
maybe i'll do the pump last so that I can return it if the issue is fixed with the filters and bulb
-Brandon
Mine had different dimensions, but I found the best price for the moeller tank on iBoats
at the shop I work at I heve seen many ( ATTWOOD) bulbs leek air and cause a loss in preasure. I recomend replacing the bulb and put a preasure tester in the output and see what you loose . but also always change the filter when any fuel suply work is done . JUST MY 2 cents
always use a primer bulb sold by an engine manufacture ie: merc/Bomb/yamaha/ Zuki.... The primer bulb will rarely stay hard while the engine is running, you have to overcome what the engine is pulling to get the bulb hard, and once its pulls that fuel, its starts to go down, you're keeping the bulb under vacuum. I would normally go straight to the low pressure pump, but they actually give very little trouble. Pull the pump off the valve cover with teh lines still connected and pump up the bulb, if you have fuel leaking past teh diaphragm, you know the pump is bad. Easy way to test the fuel system is to buy a fuel pressure test kit, they sell them at the auto parts stores for a reasonable price. One thing most people over look on Zukes are the high pressure fuel filter, its not cheap, so it rarely gets changed. If its like most of the engines i work on, the vapor separator tanks needs to be cleaned out, fuel screen needs replacing and then retest, if it still acts up, high pressure pump.
Thanks for that information. I do have the VST fuel screen en route. I'll head to NAPA eventually to get the fuel pressure tester as well!
So now, I'll obviously for (maintenance purposes) switch out the water separator filter, fuel filter, VST screen, and fuel primer bulb and test the pressures in the fuel lines as I perform the work. If fuel leaks past the fuel pump when I pressure test the lines I will replace the $140 fuel pump, if not, i'll return it.
I appreciate the help guys!
Finally got to tear into the motor. Varnish everywhere.... See below
What you're looking at is the fuel from the fuel rails in one cup and the fuel from the low pressure fuel filter in the other.
The other pics are the Vapor Separation Tank and the Vapor Separator tank filter (new vs old). This is what happens when you dont winterize your motor or use stabil...
I'm waiting on my High Pressure fuel filter and it should be testing time!
Also tore off the old (OLD) Furuno depth finder and installed my new (to me) Humminbird 788 ci. If theres an interest in a working 1983 model Furuno, throw me an offer! haha
Today i should also be attacking the compounding, polishing and waxing of the hull.
Got her out on Saturday afternoon and she runs BEAUTIFULLY!!!
I made it out to Lake Quinisigamond in Worchester, MA I spent about 8 hours on the water with 2 co-workers. Did some swimming, fishing, sight seeing and blasting up and down the lake.
This is what its all about!
I put 21 miles on the odometer and only burned through 4 gallons of fuel. I wasn't being nice on her either. I managed to clock in at 35.2 mph as my top speed. Not too shabby with the 115 on it with 3 grown men and a bunch of supplies.
Didn't do much catching, but we had a blast in the process!
