Illogikal99
I just installed my new dash and have all my gauges hooked up except for my 2 temp gauges. I had an OMC 4 wire tach for my Johnson 225 oceanrunner. I replaced this with a Faria unit and adjusted the pul/rev setting to 6, the same as the OMC tach. I wired up the new tach and after the ignition is turned on the tach needle just slowly climbs whether the motor is running or not. Ive tried switching around the signal wires as a shot in the dark, same result... Anyone seen this before?
