willy
God
Thanks to Spareparts diagnosed and repaired starter and starter solenoid problem on my 96 Evinrude 200.And replaced the leaking top valve and gasket on my primer solenoid. No more leaks.
Starts right up now, here's the problem. Engine will not get to idle speed, even after blowing the fogging oil out and exhaust now running normal the engine goes from 1500 rpm builds up to 2400 rpm, stays there for ten seconds or so and drops back to 1500, a few seconds later back up to 2400.
Even after the motor is warmed full up still won't cease that routine.
Tried some suggestions Dave and Todd had but still in same boat.
Any suggestions?
Any suggestions?
