So I would like to tackle the wiring on the boat this year. I just want everything to work correctly for once. As of now, half of the switches do not work, my tilt/trim gauge does not work, and I have too many (10+) leads going to the pos/neg battery posts. Any suggestions on where to start would be great.
http://www.flickr.com/photos/48525149@N02/
That's the link to some photos I took yesterday. In there are some pics of the current wiring (It's a mess but not as bad as some I've seen). Everything seems really simple, and I think if I take the "one wire at a time" approach it could be an easy job. The part I'm not satisfied with is the multiple leads going to the battery. It seems every time someone has worked on the wiring for the boat and added a device/light/pump, they ran the wiring straight to the battery.
How can I fix this? Is it a busbar or fusebox that I need? I can read a schematic and know what I need as far as gauge size and materials (adhesive lined shrink tubing, proper terminals and crimpers, etc)
These are the things I am going to need wired:
- Running and Anchor lights
- One or two small deck lights
- Compass light
- Garmin 500 series ff/gps
- Auto/On/Off bilge pump switch (this i want hard-wired to the battery)
- Horn
- VHF Radio
- Basic AM/FM/IPOD ready Jensen Marine Radio with two speakers
- Power Tilt/Trim switch
- Live Well Pump switch
- Gauges (fuel, tach, voltage, etc)
- Potentially the windshield wiper.. haven't decided
Other than cleaning up and replacing some terminals on the engine feed, I don't plan on doing much with that. I do have new analog gauges I'm planning to install as well. My plan is as such: once I figure out how to eliminate the numerous feeds going battery direct, I will draw up a schematic and take my time to do it right. If I can do one wire at a time, I will. If not, I'll take lots of pictures and tear everything out to start over.
But then I think to myself that my OMC Sea Drive is probably not long for this world. Is it worth redoing everything or should I just patch it up and deal with it until she croaks and then redo everything with a newer powerplant in a year or so.
I'm open to any suggestions!
- Compass light
- Horn
- VHF Radio
