mercruiser contols
aussie
hi guys is it posible to use outboard controlls on my V20 i like the trim switch on the handle
trim on the handle is available for I/Os Look for a Quicksilver commander series shifter. Normally the outboard shifter is the same unless its a stand alone box with the key switch in it, they use a different key switch. If you have a commander style side mount(or a teleflex/morse) shifter, you can just get the trim switch to up grade yours, post up a pic of the controller you have
