This is the 2nd 220hp MPI Mercruiser I had boat repowered. Last one was 2004. That setup with 3 blade prop same diameter and pitch was about 23.5kn. Installer said I was getting the correct rpm’s. One technician mentioned if I go up to a 17x19, I’ll give up top end but midrange should be better. Not looking to be a speed demon, but feel the boat with a 220 I/O should get 25-26 knots. Motor is brand new with warranty and used same Alpha drive. Not sure the ratio. Boat gets up on plane quicker and runs smooth with the 4-blade but seems to be 1 knot less at 200 rpm’s more.
