Does the linkage just push out where it attached at the side of carb? Doesn't look threaded. Doesn't want to come out easy.
When I removed the carb (linkage still attached) there were some deposits on the gasket on either side. Looking under the carb it seems kind of corroded. Some deposits in one of the channels/tubes, as well.
Can I still use this as-is to see if it runs? If so I'll see if motor runs then worry about replacement carb. With a new base gaskets, of course.
