turbinedoctor
God
Anybody have luck catching strippers on the 25's or 30's
How do you troll them?
Franco said:They work great, I used to run pull them behind wire, spool the reel with some dacron, then 150 feet of wire and use a big swivel then 50 lb mono to the stretch. The wire cuts r=the water better so there is a little less pressure on the rod and reel. If you rig a couple of reels like that you can also "wire line" for them. At the end of the wire you use a 3 way swivel. use 10lb mono on one side hooked to a big weight, upto a pound, and then run about 15 to 20 feet off the last swivel and slow trool a big bucktail or swimmin shad. If you get snagged it will break off the big weight but save the rest of the rig. It'll drag it right on yhe bottom. I used to fish the Chesapeake bay, ocean side of the third island about 30 feet of the west end of that island is a drop off and hole. I used to get my limit of strippers in an hour with 4 guys on the boat.
