Little White Plugs
I took the bow rail off this '84 and pretty much likin' it fine w/out one...but of course that leaves those nasty screw holes on the cuddy deck...found these little white plastic plugs, drilled the holes out a bit, Gooped the edges and...see 'em?
And then the skies clouded up
Still looks better than open holes...keeps a little water out too.../;^)'
Got all of 'em plugged on the bow deck and moved around to the port under the side wind shield...the PO (RIP) had an antennae mount there...more plugs...see 'em?
Oh well...I think i TOTALED this post...aarrgghhhhh!!
i used marine tex on mine
Ditto.. I've used that stuff for everything from boat repair to fixing a hole
in my thru the wall pool skimmer. (And it was still holding when the tree fell onto the pool and destroyed it 4 years later) The stuff really works well.
