cterrebonne
God
i read that this paint is a topside only paint, but if using on the bottom of a hull how long can it stay in the water? i might keep the boat in the water overnight at the most.
I really don't think you should use under the water line, even if you're just leaving overnight at most. Once you get a little water intrusion in it, it spreads through the rest some kinda bad. Just use it down t the waterline, and throw some bottom paint on it.
heck you can beat the boat with a hammer and the paint doesn't even chip or crack with that pre coat
