My 73 engine cover has a foam backed lead sheet liner,was that standard? obviously it adds a lot of weight and i am planning on removing it. I am just wondering if anyone has encountered this and if there was a significant noise increase. thanks.
My 77 has a foam filled type of insulation with a foil backing. I need to replace mine too. Ive seen something at Lowes that looks about the same that I might try.
There are reasons for the lead lined insulation... noise, fire resistance, and vibration. Like Smoke said, it does an excellent job of noise suppression, and a tolerably good job with the others. Keep it if you can. It hurts nothing, and helps a lot.
thanks for the input everyone.I will leave it be for now. I may recore the cover with divynicell next year as it has a weak spot and see how the lead holds up when i remove it.
