cterrebonne
God
I am thinking about going this route because it seems really less time consuming and I was curious as to how much I was going to need.
Seems like NYMACK used 8 gallons. He had to improvise during the pour because the stuff will find every little pinhole and run out everywhere.
It was 15 gallons, 3 pails, Ridge is correct I did make quite a mess in my driveway, You have to seal every pin hole if not it will find it.
I will recommend for stringers I personally have not done it. I did only my transom back in 08..
http://www.arjaytech.com/index.php
thanks for the post, I get to do my stringers too, so it should be fun, lol
What happens is you run out and need to pour more but the arjay sets up?
From experience I can recommended you wipe the cured surface with Acetone and re-pour, its a chemical bond which requires a clean surface..Just my 2 cents, some of the spilled Arjay, yes and I will use the word welded to my driveway cement to this day four years later!!
