if you run across a good one let me know. I don't know what happened to it, but about three years ago, I was towing an empty utility trailer, I got impatient while trying to merge and nailed it right at the same time it shifted from low to second, I felt it slip and backed off. Since then, on cold mornings it didn't like to shift, acted like a modulator valve was bad, you could let off the gas and it shifted fine, once it got warm, it didn't give any trouble. I changed the fluid and filter, put some additive in it and just kept driving it. I was in Raleigh last weekend adn my sister told me what had ahppend to it, it locked up on her, they had to drag it out of hte road, even in nuetral it drug one tire. I took it for a quick spin, you could hear the noise from the transmission, when you take off, the whirring noise got louder, I thought it might be the rear end, but the noise if definately coming from the transmission. As a friend of mine once put it " sounds like a hog knawing on rocks"
