cterrebonne
God
I am trying to figure out how thick to make my transom. Any of you guys know how thick you all transoms are?
My 86 came with a sea drive, looks like it would also be the same transom as an io, but a guesstimate on mine would be 2 1/2-3 inches.
Next time I go down to the boat I'll measure it up, and post back.
The strength isn't in teh thickness so much as it is in the layup. Also put in a set of knee braces on each side of where the bracket will atatch. Make it so that the load will go through the hull instead of the transom so much.
I put a progressive patch on my transon in between layers of 1708. It helps to distribute load from the brackets bolt pattern. I wetted out a 10x14 patch on my core then put on my first layer of 1708 that lap back to the hull 4 inches, I then put a 14x16 patch and then put my second layer of 1708 that progressively lapped back into the hull 8 inches. I put another patch that was 18x18 over that layer and then applied my third and final layer of 1708 that progressively lapped the hull about 10 inches. my core material consisted of 2 layers of 3/4 plywood. the bolt patch is just another way of adding strength and distributing load with out adding a bunch of weight. notice in the picture the dark green in the middle of the transom were the patch was layed up
Basically you added another piece of ply where the bolts would bolt up?
