Jdog
Well I did it, I had the sergery on the 9th and came home on the 11th. The surgery went real smooth due to the fact of how good I did dropping 40lbs before hand. I just wanted to let you guys know I am fine and healing fast, Thank You for all your prayers.
I also fixed my fuel restriction problem right before the surgery I got to take the boat out for a quick test run. I replaced the Main fuel line and removed the screen someone had stuck up inside the pickiup line going inside the gas tank, It was a crappy job and not factory. So now fuel goes from the tank to the new fuel water seperator, and then to a small fuel filter to the fuel pump. New hoses and filters and she runs great WOOT!!!!
