it is 3 - 6 psi, just plug all the outlets (leave the float assy. attached) except for the vent, put a fitting of some sort to that and attach to your air line with a low pressure regulator attached, adjust to the desired pressure(careful doesn't take much so use a low pressure regulator ) spray with a soap & water mix look for bubbles
