Friday night fight pics!
fishingwithblue
Still working on the tank removal but made good progress on the wiring prep. tonight. Pulled every single wire in the boat out except the tach and full gauge in the wiring harness....I mean every wire. Damn, I feel like a brand new man! Pulled crappy dash off and will replace with starboard tomorrow remounting only tach, fuel gauge, GPS and fused swithboard with busbars behind in cuddy.
This LED works awsome, got at Home Depot for 17.95, lasts 5 hours then charge 5 hours. Has 30 LED lights in it and gets the bilge BRIGHT!
Gonna spray out the bilge after tank removal. Checked out the oil pump, may relocate to fit 2 batts.
This is the thru-hull pick up for the bait tank. Gonna run new hose and pump. As you can see the open-closed valve handle has corroded off....hope its in the open position.
Clear gunnel.....
Come out damn tank! Once I get the tank out it's all over but the crying!
Gonna hit it hard Sat all day, rain or shine......getting pretty broke, anybody wanna buy a white baby?
Dang Blue!
Get after it one time! I bought my wiring from River Services in Thunderbolt. Buy it on the spool and save. Make your own battery cables too. Keep the white boy.
I'll ping you when it's cobia time.
FWB, i re wired mine about 2 years ago, i still have a bird's nest,but at least it's my bird nest. one thing i did was move the fuse block under the dash to the cabin top. it makes it a lot easier to access. i had a canvas shop make a larger flap to cover it like the original does.
