fish / depth finder suggestions
rb437
I have a Humminbird Platinum ID fish finder with the transducer mounted to the transom. This set up came with the boat. I find the depth readings are errattic. Sometimes the readings are accurate compared to charts and other times they are obviously way off (562' in the Chesapeake Bay ain't happening). Boat speed seems to have no effect. Anyone have any suggestions on what type of transducer and the most effective way to mount it on a V20? ???
You probably need to move it down towards the keel more to keep it in "cleaner" water (ie; less turbulance). I've had several Humminbird products over the years and was never satisfied with any of them.
I would recommend a Garmin, Furuno, or Raymarine (Raytheon), and possibly a Simrad. At the very least, see if you can get an Airmar transducer that works with that unit.
Squash that Airmar idea (at least I think so). Looks like they make them for just about everyone but Humminbird. Might be best to contact their tech support staff and ask the question anyways. Airmar are very reliable transducers.
http://www.airmar.com/marine/enduser/enduser_index.html
Rick, my Lowrance shows bottom and other stuff at speed ...standard Lowrance transducer mounted in back of one of the "steps" as DEEP as it will go...moving from the keel, first "step" to the port side...hope this helps... :)...
Rick, what CB and RAP said. I have a Hummingbird too and I had to lower my transducer this spring as I was getting whacky readings. It should be at least 1/4" below the plane of the hull according to my Hummingbird manual and mounted directly behind a flat surface (chine) intstead of the V of the hull. Mine was less than a quarter inch and it had a barnacle or two on it as well.
Anybody out there use the transducer anti-fouling paint?
Thanks everyone. I have the transducer located at one of the chines though I think it is at most a 1/4" below the hull. I think I'll lower it slightly and try my luck. I also noticed that the connector at the display is looking a bit weathered. Perhaps cleaning the contacts will help. I'll let you know what happens.
Rick
Throw the Hummingbird over board!!!!!!!! I hate them!!
I have Garmin 160 and its great!! works at speed or stop!!
Get the transducer off the chines!! That cause dirty water and will never work right no matter what you put in there!!
My boat came with the same Plat. I.D. I have been satisfied with it. It seems to be accurate at speeds, so long as it's not too rough.
I got the new Garmin 150 dual frequency. Have only used it once or twice, but its the best I've ever had and I can't wait to use it again!!
Need a FF and Bass Pro Shops have a Garmin 160 red. I know its only a single freq. trasducer for $99 its a recon. but you get a full 1 yr. warr. with it. Do you guys think I'd be unhappy with a single freq. transducer.
I guess i just know the diff. between a single and dual freq. transducer. Does it make that much diff. Than i guess i can decide if I'd be happy or not... Thanks
