You guys need a ref
Damn, i will re-subsribe after all.
Ben Fishin may know epoxy, I think epoxy has a much longer pot life, it is quite strong and cost more money. The fact that it cost more money is a huge drawback so the "superior anyway you look at it" approach is BS. It may be far superior to the vinylester or poly resin in your eyes as an engineer or on paper. However, I don't have a boat constructed with epoxy. My Wellcraft was all vinylester resin from the factory and it remains so after a major rebuild without any structural issues. You are an engineer, as such I am sure you are aware that engineers designed and built the Titanic. Having such a wealth of knowledge that most of us do not have, you may have come off being a bit condescending. Perhaps you should have said that you strongly believe it to be the best resin. I don't put words in anyones mouth. Resin is a wetting agent not the impact strength of a boat. Without fiberglass the epoxy is useless, same holds true with any resin. The cup of resin test defies logic. The reason the vinylester cracks is due to the thermal reaction from mixing it hot, anyone that has used vinylester resin knows that if you mix it hot it will be brittle. The correct mixture of tiny amounts of catalyst to vinyl and poly resin and the correct ratio of resin to glass is an art that has proven its durability and stood the test of time. You suggest we mix the vinylester resin and allow it to heat up in a cup beyond the working parameters of the product. You don't apply resin when it is on fire, you mix the product and get it to the glass ASAP. Because the resin is spread thin over the glass in a much larger area, the heat during kick simply dissipates.
Epoxy is in its infancy when compared with polyester and vinylester resin. I have nothing against it at all. As a layman I would think if it were stronger than the surrounding vinylester product that you were repairing it would not bend, flex, expand, contract or vibrate at the same frequency and eventually you would have a failure in the form of delamination. It may bond so well it will never come apart, can't say.
"I know so and so and You don't know crap" sounds kinda godlike, but the pissing contest is useless to the poster that wanted to know what weight of cloth he needs. I'm not even looking for glass, mine is done. Frank Sinatra
School, I don't know about the Mann boat that went down, you might be right. IMO epoxy is not the best for all applications. Most mass production boats don't use it because it is cost prohibitive and it is incompatable with gelcoat in the molds. Because epoxy hulls must be painted after, it probably lends itself to larger boats where the molds are not as tooled and the manufacturer will spend hours making the hull smooth enough for primer and paint. You may have gone off a bit early on the new guy. Sounds like he can hold his own, well educated too. But I don't suspect my opinion matters much, I am a newbie too and fully expect to fall on deaf ears.
You both got passion for the thread, I will give you that.
I always appreciated your input.
MJ - Take my name off the list for that Album would you.
