External temp guage
BigAl331
I don't have an external temp guage on my Johnson 150. I would like to have one so that I can monitor engine temps rather than rely on the "over-temp" buzzer to let me know when I am too hot.
The question is where can I mount the sensor on the motor for an external sensor? I don't have a problem with the wiring or guage mounting, it's just finding a place to mount the sensor in the motor as not to hurt anything.
I like the idea. I was thinking about trying to put something in the middle to get total water temp not just one side or the other. But this will help to narrow and temp problems to either one side or the other.
Remember V looper are design to run dual temperature port/starboard so I guessing it best to monitor both sides ? Like I said it just me :)
Single will not hurt but you may want to carefully drill a hole and tap it ..
ok then it's not a looper. look at the top of the heads for a fine threaded empty hole near the t-stats. that's where they are installed.
I would also recommend a water pressure gauge. If I had a choice, I'd rather monitor pressure than temp. That's just a personal preference thing though..
Here is my hookup both starboard and port side, its nice to see the Temp on both sides just in case there is restriction on one side I guess ?
This is sorta what I was looking for. I was thinking of keeping the warning sensors just in case.
Thanks for the pics.
yeah leave your warning sensors or your motor Al, I wouldn't suggest anyone removing those, as no one rides with the eyes on the temp gauge the whole time, a horn will tell you if something has issue in the case you were just drift fishing for example.
I am shopping on flea bay for new senders for the horn, I can't trust the old ones and besides it was never connected . I found one for 10 bucks shopping for another and I will connect it up to a horn and warning light for now I just pay attention to my gauges. Good point Skool ...
