Exhaust Bellow?
So the lower exhaust bellow on on my 1984 Alpha 1 outdrive is dryrotted and split. the guy at the repair shop said it was not a nessecary part, and did not matter if I replaced it or not.
What do you think?
I think all kinds of crap is going to get in there if i leave it go, like crabs, jellyfish and etc.
Well who ever is your outdrive guy is, Run away from him!!!
Its not there just for looks!! It carrys the exhaust to the prop and it goes ont thur there.
No bellows, will allow water to back up to the motor and maybe in the boat.
Change it!!
They have a water shutter below the elbow that keeps water out of the motor and there is no way water can get into the boat either
I don't know ANYTHING about I/Os, but I'm pretty sure that particular guy isn't somebody I'd want workin' on my boat... :P...
Posted by: redfish17 Posted on: May 5th, 2006, 6:54pm
Thats as long as the flaper isn't rotted away!! Mine was!
Try starting in your yard with out the bellows and see what happens,
1 there is no muffler (the water is your muffler)
2 water and exhust and all kinds of crap going to blow all over the outdrive,
3 the heat and water oil ect... will make the other two bellows go more quickly.
4 And if the shifting or drive bellows go it will fill your boat in short order!
Change the thing!
i dont remember saying anything about shifting or drive bellows  what I said was no way water was going to get into the boat due to a bad exhaust bellows
and I didn't say that you did ???
I said with the exhust blowing all over the other belows it would wear them out in short order!
I guess someone that has worked on a mercriser in there yard once makes them a murcruser mechanic sorry for saying anything --- just for the record ive worked on mercriser’s every day of my life for 14 years
Its amazing how you always get one person to say they are god and the rest suck!!
I never said you were wrong!! I just said that they are there for a reason, and sugested that its best to replace it, as the exhust will damage the other hoses and if they go he is in trouble.
And some how you think I was attacking you??
Well if your telling someone that they no need the bellow on there exhaust then I am glad your not working on my boat!!!!
Geez
who fellows, no need to get your shourts in a ruffle. :-X i changed the bellow it cost $19 and took a little over and hour. thanks for all the advice.
