jasoncooperpcola
God
i'm thinking about repowering my 83 V20 with an Evinrude E-Tec. as old as the transom is what is the biggiest engine i should put on it? it currently has a johnson 150 vro on it. does anybody currently own a V20 with an E-Tec?
buckleyjr said:I think the 15o/175/200 all weigh the exact same. I know the 175 and 200 do. I just purchased a new 175 etec in March. I love it. Go for the 175 or 200 - depending on what deal you can get. by the way, they make a 200 HO (high output) etec, but that is a lot heavier - weighs the same as the 225.
reelapeelin said:Jason, a good "test" for your transom is to tilt the motor all the way up and then hang your upper body across the lower-unit, applying weight to the lower-unit ...
Stinky_Hooker said:It should also be noted that the engine should NOT be running at this time. 8)
Stinky_Hooker said:ETECS SUCK!!!
Get you a nice used mid 70's Chrystler and a fire extinguisher!!!![]()
Mac_Attack said:
