Thanks, yeah when I am on plane it looks about 2" below the surface, You might have seen all my past posts trying to find out my RPM problem (4200 Max) and speed issue (32 MPH on GPS ), It sprays up water pretty good when going 4200 wondering if this could be creating drag, the pic's stink. Do You think I should move it up 1 or 2 holes? I will try to get better pics over the weekend. Thanks
I hear what Ferm's sayin' about stayin' in touch in a rough sea...but I like mine to be about 1/2" above the water on plane...least amount of drag, better fuel economy and top end...as long as YOUR BOAT will handle it that high...some will "blow out" in a turn...whether you like 'em like mine or Ferm's, sounds like yours can go up some...I think you'll like the result...
BTW...do you know how to raise/lower the motor using the trailer???
This works good on MERCS and YAMAHAS, but I have found it to result in overheating for OMC's. OMC's really need to be level with the bottom of the hull on the older ones as the water pick-ups sit pretty high. And if it is a SUZUKI you MUST have it mounted so teh cavitation plate is just below the surface or else you will FRY the engine as they use dual pick-ups(one on the side of the foot and the other is underneath the cavitation plate).
Well pulled the boat for the season today, upon inspection I found the cause of the rattle. A while ago I had a rattle and found out it was my trim rod rattling when I went over 2000 RPM's because the water was pushing up against it. I used 5200 all around where the trim rod goes through the bracket, rattle was gone, used it all summer, no rattle. Well the 5200 let go and the rod is loose again. I think when I raise the engine I won't have the water forcing up against the rod and therefore no rattle. By the way do I need that trim rod? it doesn't seem to do anything, even when I lower the engine all the way down it doesn't touch. Thanks
