Not as easy as the cuddy, but not much harder. Should be able to remove screws holding down console and lean it toward the side the rigging tube is on and rest it on the gunnel. Then remove the tank hold cover.
I' never done a wellcraft cc, but helped a friend do a 19 mako. I did do my cuddy, fighting the foam is the biggest problem. Might be easier to completely remove the console, set it on the bow.
I did my 86 20cc a while back, it wasnt too hard, unhooking and rehooking the center console was hardest,you might want to check the deck once the console is off because thats the time to repair it, something i wish i had done,
