the check balls Ferm is talking about are inside the hoses that go to the risers, its in that T fitting in the top of the housing, if they aren't in there, or if the spring is gone, it will overheat
I've done it in a boat ramp parking lot before.... takes about 15 minutes if you're experienced and 1 hour for a novice... not hard at all
That impeller got run dry is what did it in. You can tell by the wear on it as age tends to just lay the vanes over whereas running it dry burns them off. And put a 140 t-stat back in it since it is a raw water cooled engine. You could do a 160, but the 140 seems to work better and reduce temp spikes from my experience.
