Not hard at all, My engine has the same type of carbs.
Its important to note unlike the metal carbs these plastic ones do not get submerge in any type of cleaning solvent period just use any carb and choke cleaner and spray away.
Mark each carb as you remove it , take it to clean work area and do your cleaning, have a compressor or compress air cans you will need it to flush the jets clean.
Observe each jet as you remove it , each one is stamped with its bore size on the side and top of the jets .
Hoses should be secured with not metal clamps but plastic tie wraps or snapper clams from OMC if you like.
I use my angle grinder to shape regular flat screwdriver to fit into the hole to remove my high speed jets (OMC tool my A**)
Very important NOT to use gasket sealer to attach the carbs to the intake/throttle body it will clog the air way
Float adjustment is key, Let me know if you need info on it..
Post pictures and double check your work..
See attached diagram..
