the daydreamer
question i know that i have read a post about shorting the bow rail. my question is if you cut some off of the rails will it change the angle? seems that it would just make the back longer?your thoughts thanks!!
if you shorten the verticals(that are angled forward) it will move the top rail aft as well as down. so if it currently hangs over the bow, it will then be above the bow. hope I'm making sense...
Not sure why you would lower it. It would be even less useful then.
It does help when you sit on the bow with your feet dangling. Also helps as something to grab when launching/recovering.
